Motor is misfiring help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2005, 09:40 PM
Ok here is my problem my car has had a miss since the day i bought it. When it idles u can here it cut out it sounds like it is only one cylinder because it has a pause between cutting out. It also above 5,000 really starts to cutout and struggles to get up in rpms it gets poppity. I have ran 3 different top ends on this motor. First was the factory TPI. Second was a stealth ram setup. Third it is now carbed. Had 3 sets of wires 3 coils and 2 distributors. The motor is a 92 chevy truck 350 the guy before me rebuilt and i bought it with 2,000 miles on the motor. The guy put a small cam in it, XE262HR other than that the bottom of the motor was rebuilt to stock specs. Does anyone have any ideas as to what might be wrong?
Old 02-25-2005, 11:50 PM
Are you sure the cam is not flat?
Old 02-26-2005, 05:31 AM
willowbilly3's Avatar
Last journal entry: Body mods
Agree, sounds like a typical flat chevy cam. Could be a broken intake valve spring. Have you put a vacuum guage on it? Do so and note the readings A bad valve or valve spring with show as a sharp quick dip on the guage for every engine revolution.
Old 02-26-2005, 07:03 AM
A broken intake spring wont make it miss. It will make it pop through the carb. A broken exhaust spring will make it miss. I had 3 broken springs 2 exhaust and 1 intake so thats where I got my info. Pull all the plug wires 1 at a time with it running. Watch a tach and see the difference. Is it just 1 cylinder? Does it move around? I would do a compression test. See if thats ok. If it has good compression and it comes down to 1 cylinder then you could have a broken spring, a bad cam lobe. or not getting fuel to that cylinder. The last one is not likely if your using a carb. If you suspect a spring try pushing the valve open by hand while its not running. On my motor the only ones I could move were the ones with broken springs.
305 Misfiring Silver_Camaro Engine 14 01-14-2004 09:17 PM
misfiring i think mustangman1968 Engine 2 12-09-2003 01:16 PM
What's the best way of checking for a misfiring plug Jag Daddy Engine 21 07-14-2003 10:53 PM
