motor mount bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2004, 07:44 AM
airman_turtle's Avatar
motor mount bolts
ok, to make a long story short, i found all three bolts that connect the motor mount to the block to be missing yesterday. When you rev it, the engine actually slides up and down on the mount. Its a small block chevy, do i have to lift the motor all the way out to replace them, or can i just get away with lifting it a little bit.
Old 09-23-2004, 07:55 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Personally, I would take out the big bolt that holds the two halves together, bolt the upper back on the block, then set it in place and put the big bolt back through.
A little jacking should be sufficient.
Why did the bolts come out in the first place?
Old 09-23-2004, 07:57 AM
i sadly think i have to say i didnt tighten them enough lol
Old 09-23-2004, 07:58 AM
Lonestar's Avatar
oops, I think you had better check every other bolt in the car.
Old 09-23-2004, 07:59 AM
yeaaaaaa
Old 09-23-2004, 06:38 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
You sure it's just loose or missing motor mount bolts? This is a "classic" symptom of a FAILED Chevy motor mount! Good Luck ...either way. ...Mark
Old 09-23-2004, 06:42 PM
Siggy_Freud's Avatar
Use some medium thread locker to help prevent them from coming out under vibrations. If at all possible to a check after a couple days and then again after a few weeks to make sure they are snug. I also used lock washers on mine and (knock on wood) they are all still there lol.
Also . . . as long as they are out . . . get new ones. They aren't that expensive and its good to be safe.
Bringing history and technology together.
Old 09-24-2004, 07:38 AM
took care of it yesterday, only took about an hour, that sure is a lot better haha thanks all
