motor mount to frame bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2008, 02:50 PM
any ideas on how to remove the motor mount to frame bolts on a 1981 buick regal,the bottom bolt i can see from underneath the arm but the remaining top 2 remain a mystery on how to hold the bolt head with a # 15 while removing the nut,there is a slot on the mount but the angle is wrong to get a wrench in there to hold the bolt head, ineed to get them off or loose to change the rubber mount between the 2 piece mounts. jada
Old 02-26-2008, 06:51 PM
re:motor mount to frame bolt
Hi can you tac it with a welder? or try heating up the 15 mil and bending it to fit! TROY
Old 02-27-2008, 08:29 AM
The problem is that these bolts are installed before the lower control arms are bolted in place. I'm wondering why you need to pull the frame mounts to get the rubber motor mounts out. You should just be able to raise the motor with a hoist or floor jack.
Old 02-27-2008, 11:09 AM
re replacing polyurethane inserts in frame mounts
thanks for the reply,i have the engine out of the car and both engine mounts from block to frame mounts removed,to replace the poly inserts the "clamshell" mounts have to be removed or bolts slackend off enough to push out the old inserts and push in the new ones.can this be done without removing the control arm? the clamshell mounts to the frame are two piece with insert between
Old 02-27-2008, 12:36 PM
DRS50's Avatar
Last journal entry: Epoxy primed the body today
I replaced the mounts on my camaro when swpping the v6 to a v8, its not easy but a rachet and 6" and 3" extension and a swivel knuckle and the right size socket going in from the bottom and the wrench on top is how i did it. You have to finagel it around to get the socket where it goes. It was not the easiest job i have done and my wife said that there was a few more words than usaull coming from under the car.
Old 02-28-2008, 09:34 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
You sort of just have to get in there and do it, i remember going through the opening in the frame where the control arm attaches. Also I bent up an old 12 point wrench to fit in there nice where the ratchet was hard.
Frame mods dusterbd Suspension - Brakes - Steering 5 11-05-2004 01:00 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
57 chevy frame alignment question... please help! Sanspants Suspension - Brakes - Steering 1 07-20-2004 10:15 AM
Custom Frame (Long) Toyman Suspension - Brakes - Steering 1 08-29-2003 09:43 AM
repairing a cut up frame jniolon Suspension - Brakes - Steering 3 04-12-2002 06:42 AM
