Motor Mount Mystery - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2006, 07:07 PM
Motor Mount Mystery
Pics are here
I believe they are for a big block Chevy, but I'm not sure if they are for the frame side mount or block side mount.
I got them in a box of auction stuff.
Thanks,
Kurt
'72 El Camino in resto
Old 01-05-2006, 09:39 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
those are typically called the "cup" it goes on the block the one looks like it might be bent the left one
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 01-05-2006, 09:54 PM
MI2600's Avatar
Member# 3287
They look like they could be small block mounts. They mount on the block. I always thought they fit either side.
I'm not familiar with big block stuff.
But they are for a big block bowtie, right?
Kurt
Old 01-05-2006, 09:58 PM
MI2600's Avatar
Member# 3287
These are small block mounts.
Old 01-05-2006, 10:32 PM
big block and small block in CHEVY motor used the same CLAM SHELL mount.
the only thing you might run into is there are taller ones for truck and shorter ones for cars. i ran into this myself
if there is a diffrent then i been using the wrong mounts all this time.
Old 01-06-2006, 07:11 AM
Rob Keller's Avatar
Wiki Edits: 38
as far as I knowthe 'clam' or "cup' is the same there are all kinds of towers and spacers for van & car & truck appliations .
and the "pad's are all the same too ...as far as I know
SR66
"SlowRide66"
Old 01-06-2006, 01:50 PM
Bluejackets67's Avatar
If I'm not mistaken, these look like 1988-98 Chevy/GMC fullsize truck motor mounts (Big or Small block). This bolts to the block and the vulcanized rubber mount bolted to it and the crossmember.
Old 01-06-2006, 03:23 PM
they go farther back.
Old 01-06-2006, 05:58 PM
Rob Keller's Avatar
Wiki Edits: 38
early 70"s like
1974?
SR66
"SlowRide66"
Old 01-06-2006, 06:07 PM
poncho62's Avatar
Wiki Edits: 5
That style of mount came out in about 73................Big Block and Small block Chevy mounts are the same.
Before that style, big block mounts where a little narrower, but could be used on a small block.
Old 01-11-2006, 08:32 AM
Tazz
I have a set of those too
Mine came off a 77 Impala wagon frame.
Tazz
Mystery Bubble? Dragon J Body - Exterior 4 10-28-2005 02:08 PM
mystery convertor CombatWombat Transmission - Rearend 3 03-14-2004 10:48 AM
Marvel Mystery Olil Dave E Shank Engine 39 07-28-2003 10:21 PM
mystery rearend witty Transmission - Rearend 3 03-31-2003 02:37 PM
67 Camaro mystery plug sudo1a Electrical 2 01-11-2003 06:12 PM
