motor mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2003, 08:36 AM
Post motor mounts
I am building a 48 ford coupe with a 454 and mustang front end kit should i use side mounts,or a saddle type mount under the motor to help tie the frame together ?
Old 05-20-2003, 04:30 PM
Post
The side mounts will work fine, the Mustang 2 crossmember will tie the frame together.
Good Luck, Mark
