motor mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2003, 07:01 PM
robbysapien's Avatar
383nova76
motor mounts
i am puting a 350 in my nova and i need to get the mounts can i use any smallblock mounts? (i am finally geting rid of my 250!) thanks a lot
Old 10-27-2003, 07:08 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Yes, but the ploy mounts are better.
Luv the smell of NITRO in the morning.
Old 10-27-2003, 08:51 PM
You need the engine brackets that go between the engine & the mount. I think the mounts are the same for the V8 as for the 6, but check at a parts store to be sure. The plates can be found on a 75-79 Nova (or clone) with SBC engine, or maybe a similar year Camaro, and they were still available from GM as of a couple of years ago. Try to find an intact V8 junker in a yard & pillage it for the plates, accelerator cable, etc.
Old 10-28-2003, 07:18 PM
i did this swap a while back and yuour gona need the small block mounts...and then your gona have to do a little drilling to get the new mounts onto the crossmember..member messure 2x and cut once
Old 10-28-2003, 08:04 PM
383nova76
alright but besides the drilling the swap is pretty straight foward? this is my first time and i want to make sure i dont mess anything up i have been looking for a nova with a sbc in it but i cant find anything in wrecking yards all i find is they dont have a motor or that have a 6 just like mine can i buy them new? if so how much do you think they would cost? thanks a lot i apreciate all of your help
Old 10-29-2003, 03:09 AM
The plates were around $18 each from GM a couple of years ago.
Old 10-29-2003, 03:24 AM
Frisco's Avatar
Glad To Be Here
Go to http://www.chevy2only.com for everything you need to install a small block into your Nova.
Old 10-29-2003, 04:34 PM
383nova76
alright thanks a lot i am going to get everything i need to do it right. but i have a question, do you think 200 is too much to pay for a zz4 crate motor that needs to be rebuilt? and also the owner dropped a bolt in it so i have to search for it. i cant decide if i should buy it thanks a lot
Old 10-30-2003, 03:10 AM
Sounds like a decent deal, assuming the motor runs, but has not been run since the bolt went in.
Old 10-30-2003, 04:03 PM
383nova76
it doesnt run but they said it needs a timing chain and it hasnt been ran since the bolt was droped in. but im kinda leary about it because some people that heard it run when it did said it didnt run right but im going to rebuild it so it doesnt matter much thanks a lot
