Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Motor mounts for a 39 ford pickup
Old 11-09-2011, 11:51 AM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
Originally Posted by speedbump
It's all great if you're a fabricator and ya want to do some $500 motor mounts.(your time at $20 hr, materials and consumables) The Speedway, and others, solution is an acceptable mount for a boxed frame that only requires one weld per side and does the job in a clean, simple fashion. I applaud creativity but many don't have the equipment and sometimes it just isn't worth it.
Man !!!!! You got to be joking !!!!!
This statement say's it all...
''it's not about the destination, it's about the journey''.
Motor mount's can be built almost as fast as it takes you to order your's....
The great thing of building them...You can make something that speedway doesn't sell like these..
I buy alot of things from speedway don't get me wrong,,, But not motor mount's...
And it doesn't take more then a hour and you don't have to have special tool's to do it..
Even been told I don't build them right..... Go figure !!!!
ID:	59562   Click image for larger version
