Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Motor mounts for a 39 ford pickup
  #19 (permalink)
Old 12-12-2012, 06:56 AM
timothale timothale is offline
Wiki Edits: 27
motor mounts
The motor mount engine location depends on the trans you will be using. With a ford flathead trans speedway sells the front mounting kit. but they should not be used with a trans that has it's mount near the rear of the trans. The 50's V 8's chevies used transmission mounts on the bellhousing and the front mounts will work ok with those , Just don't have the mounts for the engine and trans so far apart it binds- bows the engine trans.
