Well to some of us here that do this..... It is easier to build them,Then to buy them... And my case anyway... If I order from someone it takes me two to three days for it to come in.... So for me it's easier to just build them.... In them three days I can have them done,,Motor in, And more then half way done on the narrowed 9''...
So In some case's, It's better to build, then buy.... I buy the thing's I need that won't hold me up... Something as small as a mount... It will get built and Then I move on.... Mirrors,key switch's,Light's,steering wheels,lug nut's, That's the stuff I order... We didn't mean to having a p***** match here... But What you think is easier to buy,, We just feel it's as easy as buying it, To build it..... We gave a opinion,, Just like you did.... It's up to him what he want's to do...
Wow, I have decided to build my own. Was looking for a solution that I would not invest too much time or $ into. Sorry for some reactions. Guys, it was just a question. Since I am in my middle 60's the testorony issues are mostly behind me. Plus the loss of my good brain cell didn't help.
Thanks for the input!!
motor mounts
The motor mount engine location depends on the trans you will be using. With a ford flathead trans speedway sells the front mounting kit. but they should not be used with a trans that has it's mount near the rear of the trans. The 50's V 8's chevies used transmission mounts on the bellhousing and the front mounts will work ok with those , Just don't have the mounts for the engine and trans so far apart it binds- bows the engine trans.
I gotta say it - New Interiors, those are the nicest motor mounts I have ever seen! If those were on my sedan, I'd have to leave the hood sides off just so people might get to see them!
| '34 ford motor mounts | lamothe1 | Suspension - Brakes - Steering | 6 | 08-19-2010 06:38 AM |
| 49 ford motor mounts | WeeWilly | Engine | 3 | 04-11-2006 09:23 PM |
| 34 ford on s10 frame motor mounts | jaxhome | Engine | 2 | 04-03-2005 10:15 PM |
| Ford 390 FE Motor mounts | chadzeilenga | Engine | 1 | 08-18-2004 03:16 AM |
| '40 Ford Pickup cab mounts | alittle1 | Hotrodding Basics | 5 | 04-03-2004 06:41 AM |
