Motor Mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2006, 12:58 AM
65Stanger's Avatar
Check the water, check the oil
Motor Mounts
I'm thinking about putting new motor mounts on my 200 ci L6 3.3L engine. The reason for this is a bit of vibration from the motor, but more importantly, the only time that it rattles really is when I turn the steering wheel all the way to the left or right. Could this be mounts? I want to correct this problem right away. Thanks guys. (also, anyone know of any good mounts?)
Old 04-10-2006, 09:29 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Or drag on the pump?
Old 04-10-2006, 09:42 AM
new motor mounts ($20? local store) is worth while because it adds strength and less flex (acts as a crossmember) to the worn and weakened unibody
slim to no chance it will fix the steering
there are to many possible causes to list all (worn ball joints, bad bearings, worn spindles, alignment and strut rod bushings, upper arms bushings for a few) without actually doing an inspection
can be obvious to someone who knows what to look for, ask the guys in the tranny shop where you work and motor shop next door to inspect it for you....otherwise take it to a alignment shop (like you said you were going to)
Old 04-10-2006, 01:15 PM
65Stanger's Avatar
Good call Red.
