The last couple Chevy powered rod builds I used the Moroso engine brackets they use for a solid thru bolt and modified them to use the Welder series design where the frame bracket has the tube with the rubber or poly bushings. Pieces are available from speedway as well. The rubber or poly is inside the tube so if it wears. splits etc the engine is still in place and can"t move much. http://www.summitracing.com/parts/mor-62510?seid=srese1&gclid=CLb80-LvnsgCFUuVfgodd8AOkA
the welder series has the tube and bushing on the engine piece. I make them on the frame piece to use the Moroso bracket.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
