Motor Mounts For Camaro Clip In '57 Chevy Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2006, 10:57 AM
tmeyer's Avatar
I am researching what to do about motor mounts. I was wondering if anyone has used the stock camaro mounting points for the engine location. If not, why not? Does this postion the engine to far forward? This sure would be easy and would put the engine in the engineered position for the subframe. I am just trying to learn for others who have "clipped" their 55-57 chevy truck.
Old 07-10-2006, 08:49 AM
I believe the engine would end up in the wrong place ...
Old 07-20-2006, 01:31 PM
1939d2/s10's Avatar
engine mounts
I have seen the stock mounts used,the engine sits very low in the compartment,it may handle better but it was hard for me to lean over and work on the motor.I ended up putting 2 inch spacers to bring the motor up.Good luck,Johnny
Old 07-20-2006, 02:14 PM
tmeyer's Avatar
Thanks Johnny, I have followed this advise and moved the motor up a few inches...
Old 07-20-2006, 06:03 PM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
Things to check:
1. Ability to pull the distributor without firewall interference.
2. If running a mechanical fuel pump, check interference with cross member. I had to notch mine for clearance.
3. If running full length headers, install engine at a height that will keep the tubes off the tarmac (above the bottom frame rail surface)
Old 07-20-2006, 06:13 PM
rj57's Avatar
A woman one of my sisters used to work with, her husband did a Camaro sub frame in a '56 Chevy truck. He used as much of the Camaro parts as he possibly could.
I don't know 100% of the details to his conversion but the build looked nice the times I saw the truck.
51 Chevy 1/2T Pick Up - Front Clip Question mwskopf General Rodding Tech 10 10-14-2015 06:23 PM
Mustang II IFS Install in 57 Chevy Truck mestes Suspension - Brakes - Steering 7 01-24-2012 09:12 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
chevy 396 truck vs car engine MPCzehura Engine 4 11-28-2006 10:07 AM
suspension for 57 chevy truck savage57 Suspension - Brakes - Steering 1 06-21-2006 11:51 PM
