Motor Mounts Chevy 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2003, 06:57 AM
Post Motor Mounts Chevy 454
Ok i have posted bout this before, but I have a 79 Trans Am with the 403 olds motor and i'm putting the chevy 454 in it from a 86 Suburban,
problem is that i can seem to get motor mounts that will match frame stands for my car anybody got an sugestions, different frame mounts?,motor mounts? or where to get them? or adapter plates or anything helpful,my e-mail is big_white_hog_guy@yahoo.com
Old 03-19-2003, 02:40 PM
bigwildgrin's Avatar
Rooster
Post
I must be missing something. why can't you cut out the old Olds mounts, bolt the 454 mounts to the block, drop the engine in and align it where you want it, then tack weld the mounts to the frame. pull out the engine and give the mounts a good weld. there must be some reason why you can't do this, but just in case you've missed the obvious...
Old 08-08-2003, 01:57 PM
Ken. P.'s Avatar
hi guys and ladys. im new to this forum and i have a few questions. so here gos.i have an 1980 trans am with a pontiac 455-4spd.and my question is. i want to put my 454 from my elcamino into my T.A. and i've put a 454 into a 73 ventura once and i did what you guys said. i put the mounts on the motor and put it in then welded the mounts in. but i dont want to do this to my trans am because i would to put the 455 back in one day so my question is .can you buy a convertion kit that will allow you to do the swap with out changing the lower frame mounts.and if there is can somone tell me who and how to get them.and will my hedders from my 70 elcamino fit the trans am.there hooker comps.any help would be great.im hoping to have my 454 in the car so i can go racing next weekend.aug 15 to 17.
1970 SS 454-4spd elcamino 410 possi.1980 trans am CBB4spd 410 possi.
Old 08-08-2003, 04:02 PM
I would get nova big block frame mounts which should bolt in just fine and just use the motor mounts that are on the engine. One thing to remember is that you want the clam shell or safety type frame mounts of you are going to use the truck engine mounts with them. I can't remember what your they switch over to the clam shell type mounts I think its was about 72 I'm sure some one here will know for sure.
Old 08-08-2003, 04:46 PM
crossfire84's Avatar
Tri-Powers are cool
454 mounts
this is what i did to my 77 T/A , went to my chevy dealer and ordered upper and lower mounts for a 1970 BB camaro, no welding. i did have to drill new locating holes in the front cross member, before you drill drop the BB & trans in, bolt the trans to the cross member this will tell you were to put the new holes, this way the drive shaft be correct and any other hook up. hope this helps you.
Old 08-08-2003, 08:14 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Thats what I was getting ready to say, 70 up camaro should work
Troy
Old 08-08-2003, 08:33 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
I was gonna say this if you decide to weld the mounts in. Don't let the full weight of the motor rest on the mounts when mocking it together. You'll play he!! getting the bolts through when it's time to set the motor on the mounts after welding. Just let the mounts come into contact with the crossmember and it'll set in there perfectly when you put the motor back in.
