MOTOR MOUNTS (Engine Mounts) - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2009, 10:21 AM
Last journal entry: Done with the Engine
BIG Problem!!! My '75 Ford Courier... "Getting a 140 c.i. '76 Pinto Engine Won't Mount with the 1800 c.c. engine, Mounts & Can't Find any Adapters. The '78 Courier Came with a 140 c.i. But, I Cant Find any Mount to Block Part.
Old 08-27-2009, 01:32 PM
It's not Anchor P/N 2774 and 2775?
Apparently those are the same P/Ns for the 1.8 L engine in both 1975 and 1978 as well as for the 2.3 L in 1978. Of course, Anchor is not always correct on their applications...
Old 08-28-2009, 09:52 AM
Thank You For Your Reply!... I Bought Thoes Mounts. But "see the 3 Studs Shown in the pic?" There are metal connecting brackets to them; that bolt to the block. they must be different between the 2.3 & 1.8.
I Saw an '85 Courier, in Pick your Part: But, the mounts were totaly different. I would need to cut the entire motor mount system from the frame, of mine & the one in the salvage yard, than weld the new ones in; to swap.
I have the truck ready to put engine and trans in; than design motor mounts needed. (unless, I find the brackets for the 2.3 for thoes motor mounts.) Engine & Trans are 24" longer; so the rear mount will be fabed too.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
fab gmc 250 engine mounts? 31chevy Engine 2 02-09-2008 06:02 PM
Engine mounts Jackyl Engine 1 10-18-2004 08:30 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
