motor mounts for a top hat frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2008, 07:29 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
gonna drop a 350 in an old stude with a top hat frame. Any suggestions on which type of mount to use? frame stiffener? saddle bracket?
Old 04-30-2008, 07:46 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Speedway has a universal type mount for those engines..
91018031
Universal Weld-On Motor Mounts.. these are for the frame side..
91018012
S/B Chevy Rubber Motor Mounts..these bolt on the engine..
Something like that should work..
Sam
Old 04-30-2008, 09:25 AM
oldguy829's Avatar
Wiki Edits: 88
motor mounts
Thanks that should work fine.
The frame is only 13 gauge. Any recommendations on how thick/ how large a plate I should back these up with?
Old 04-30-2008, 09:49 AM
Wiki Edits: 3
What I did do is buy a sheet of 10 gauge to make gussets and pieces out of to reinforce things like that..Now if I need something I just whack it out..that sheet of material should last thru several projects..Just make the reinforcements as big as you think you need..Overkill is better than falling apart..
Sam
frame pics willowbilly3 Hotrodding Basics 6 12-08-2006 10:25 AM
Critique My Frame STATUTORY GRAPE Suspension - Brakes - Steering 23 12-21-2005 08:51 PM
sub frame attachment Ricky Rocket Suspension - Brakes - Steering 4 09-18-2005 09:59 PM
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 08:42 PM
