Motor offset how much is accecptable ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2011, 04:18 PM
I have done a search on motor offset and it seem that if the motor is offset but still paralell in the chassis this is not a problem ? But is a motor that is 2 inches offset to one side accecptable ?
Thanks
Old 06-29-2011, 04:27 PM
Thanks
The output shaft of the trans is ALWAYS offset from the pinion on the rear end in the up/down direction. The u-joints neither know nor care whether the offset is up/down or side-to-side. The only thing to look out for is not to exceed the maximum allowable angle on the u-joints.
Old 06-29-2011, 04:40 PM
Joe thanks for your reply this must be your specialist area as when I searched I see that you had replied to many of the post LOL. When I had my axle narrowed I went for a centred pinion so with my motor off to the left 2 inches when veiwed from the front and the pinion in the center of the chassis and the wheelbase of the car is only 89 inches would you say that Im with in the max angle the UJ can opperate ?
Thank
Old 06-29-2011, 07:51 PM
68NovaSS's Avatar
Wiki Edits: 9
There is a difference between side angle and up/down angle. The relationship between the trans output shaft and pinion angle is important, the angles need to offset each other the same amount. Spicer recommends not more than a 3 degree compensated angle, that's up and down angle. Three degrees is very conservative, but a joint's life at 15 degrees is cut in half at 30 degrees, which is excessive. Suspension plays a big part as well, I run a solid 4-link, with very little movement under acceleration, therefore my setup angle was very tight with no movement or suspension flex.
Google "drive shaft angle" for some good information.
Old 06-30-2011, 02:58 PM
Sorry, but the driveshaft is rotating. The U-joints cannot differentiate between up-and-down and side-to-side offset. Yes, the trans and axle pinion need to be parallel in BOTH directions. Other than that, all the U-joins know is the max angle that they see while rotating. There are LOTS and LOTS of mechanical drive systems that use driveshafts with U-joints offset horizontally, vertically, and every angle in between.
Old 06-30-2011, 04:51 PM
68NovaSS's Avatar
Wiki Edits: 9
I understand that, and think you said what I meant. There are indeed maximum angles, and there does need to be some angle to allow the needle bearings to rotate. I'm addressing primarily up and down relationships in my post.
And yes, virtually all vehicles are offset to one side or the other. Like the OP, I had my (FAB-9) housing narrowed, centered, it's a back half car. I don't know what you're sorry about, I think we're on the same track.
Old 07-01-2011, 12:18 AM
Thanks for your reply guys I have redone my the engine mounts and now im just 1& half inches offset so I think Im well with in the max UJ angle
Old 07-01-2011, 04:18 AM
The driveshaft is only designed to operate out of plane in a single direction. Offset of the moter means you have to offset the pinion the same amount otherwise it will operate in an eliptical fashion during
suspention travel.
Old 07-02-2011, 08:54 AM
3rdmember
Thanks
yep, sounds like you're working on an amc....
Old 07-02-2011, 09:09 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
suspention travel.
Not really, as long as the engine is still kept perpendicular to the differential. If the engine was installed at an angle, then there would be a problem. I have seen some drivelines run at odd angles in heavy equipment with no problems.
think my trans or motor is offset chuck whitaker Transmission - Rearend 10 08-01-2010 06:57 PM
offset rockers or not? 59 wagon man Engine 7 06-21-2007 09:14 PM
hypoid-offset soren60 Transmission - Rearend 2 02-27-2004 03:56 AM
offset??? classic_chevy_guy Suspension - Brakes - Steering 1 10-16-2003 01:04 PM
Offset centerline kidvid Engine 2 12-13-2002 08:36 AM
