Motor oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2013, 07:27 PM
Motor oil
Hello. I have a 350 Chevy that is suppose to have around 425 horsepower. I don't know any particulars about the engine. It has a fairly radical cam, 750 Holley. I am wondering what motor oil I should be using in such a motor. I have 10-40 in it now but have driven it only about 5 miles since I just got the truck done. The guy that had it built and I bought it from has relocated, but I know he drove it very little and raced it at the classic drags a few times. Should I be running maybe 10-30 synthetic in it or what. Thank you.
Old 02-08-2013, 09:19 PM
If it has decent oil pressure with the 10-40 leave it alone. A synthetic oil is helpful in cold weather for starting the vehicle. A heavier oil is good for racing and constant high RPM's. Nothing wrong with conventional oil.
The Following User Says Thank You to cadillacdave1 For This Useful Post:
rustman (02-09-2013)
Old 02-16-2013, 01:33 PM
35terraplane's Avatar
I also would leave the 10-40 in it, it is a good weight oil for engines that don't get used much. I run it in mine or I run st 40 weight.
Bob
ew motor what oil? cutthroatkid Engine 36 01-16-2010 03:09 PM
motor oil ? runn141 Engine 12 09-05-2006 08:17 PM
motor oil inquiring_mind2 Engine 9 02-13-2006 05:22 PM
can you put senthetic oil in a motor that has always had conventional oil in it? batman09 Engine 8 08-16-2004 06:53 AM
motor oil ron eckman Engine 3 01-03-2004 05:11 PM
