motor puts out power like boost? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2012, 09:08 PM
Brian Morency's Avatar
Hauling A55 BURNING GASS!!!
Last journal entry: bros car
So today I was testing the car out. It seems that from a stop. Foot break stall till 1800 then off we go. 1st gear from 2g till about 3600 it pulls good but when it hits about 3800rpm it suddenly takes off breaks traction like its some sort of boost?
I don't understand. Can someone help with some info on what might cause this sudden BOOST of power?
Am I missing something? Am I just dumb?
Old 04-20-2012, 10:04 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Where's the power band of your cam? Probably just hitting it.
Semper Fi
Old 04-20-2012, 10:18 PM
I have no idea. I bought the car with no info. I've changed the carb and that's about it. First time taking it out and really getting on it. The previous owner did mention a performance cam. Just not sure what size. I never drove a car that had sudden power at higher rpm like that. Guess its just me being new to this game.
Old 04-20-2012, 11:04 PM
dinger's Avatar
68Nova nailed it, it's the cam profile.
Have you ever rode a Kawasaki Ninja? When you hit about 5 grand on the tach, you feel like you've been hit from behind, the motor goes monster on you. You better be ready for the take off, the first time I did this I was not ready, I had to pull myself forward on the seat so I could let off the throttle. Scared the crap out of me the first time, the second time it was a thrill. The cam I just yanked from my coupe had the same profile but I didn't build the car for speed, I wanted more low end torque. What you have would be great for circle track racing or drifting where you want to keep the R's up high.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 04-20-2012, 11:33 PM
Thanks. Yeah I've drove a ninja 600 wheeled on me at those rpms. I guess its the cam. It surprised me tho with the 305. Might be bored over like the last one I had
Old 04-23-2012, 08:38 AM
So basically, when a engine reaches the cams power band then the motor comes alive?
Old 04-23-2012, 09:23 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The feeling of "coming on the cam" you're experiencing is accentuated by not having the optimal gearing and optimal stall speed torque converter.
Ideally, you should be set back in the seat and stay planted there through the rev range. Instead of that, you have a lower stall RPM than the cam/engine combo wants, and possibly you're geared higher (lower numerically) than you should be. This causes the engine to accelerate slower until it hits the power band, and that is the feeling of "boost" you have noticed. the engine will accelerate the vehicle, but slower than if the gears/stall speed were allowing the engine to start off in sweet spot of the power band.
I would suggest you find out the cam specs, or get the part number and look the specs up. Knowing that, along w/the compression ratio and the other things about the engine like what type heads, intake, carb, exhaust system, etc., will let you choose the rear gear ratio and/or torque converter to match the engine. You might look into an OD automatic trans. That will give you a low first gear- even with high rear gears- and the OD will let the engine spin slower at highway speed, especially beneficial if you install lower rear gears like 4.11's.
Old 04-23-2012, 07:56 PM
Thank you this its all very useful information.
The only things I know about the car is, Edelbrock 600cfm carb, performer intake, full tube headers (not sure size) into y-pipe then a dump. Pretty sure stock torque converter on a th700r4 to stock rear end gears 2.73 with limit slip.
Boost referencing power valves. 427blownvette Engine 5 12-31-2010 09:25 AM
More boost less horse power? F-MAN-SS Engine 2 11-01-2009 08:07 AM
hydro-boost vs. power brakes pittbull7934 Suspension - Brakes - Steering 24 08-20-2009 06:26 AM
how do i boost power for my flathead? flatheadfever Engine 1 12-06-2005 06:59 PM
Help..Power Brk Boost. Vac. 454impala69 Suspension - Brakes - Steering 3 02-06-2002 11:54 AM
