motor questions, suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2005, 11:36 AM
Chevy stuff makes a Ford Tough
I have a '69 Nova that had motor problems and now I need to build a new one. I found a replacement motor, but is basically a stock rebuild. The motor is a 350 with stock punched cylinders(0.020 over) that has stock replacement pistons and I was planning on putting my cam, heads, and intake on it. I have a Comp Cams Magnum 280, Edelbrock Performer RPM Air-Gap, and stock '76 heads off a pickup with 1.94/1.60 valves and are most likely 76cc. All these parts were on a 350 that was punched .060 over. What effects would this cause going from a .060 over to a .020 over? I am running a set of Comp Cams Magnum 1.52 roller rockers, but also have a set of Erson 1.60 roller rockers. If I installed the Erson's would I have to put screw in studs on the heads and would they affect my performance (the springs are matched for the cam)? Could I use both for a 1.5/1.6 combo or just use one or the other?
My first goal is to get a new set of heads, but am in query of what to get. This car is an everyday driver and would like to keep the gas prices down by using less than 92 octane everytime I fill up. I've been told that with the setup I have now I'm running about 8.5 cr and would like to boost that some. Will 58 cc heads put my compression ratio too high, or would 64 cc heads do just fine? Also, I'm on a pretty tight budget so was most likely lookin for some used heads or anything under $600 complete. I've seen that ProToplines cast iron heads run for about $470, but am not sure if that's each or a pair.
I've also heard about putting a 327 crank in a 350 for a wicked combination. Has anyone had experience with this and what would need to be done to accomplish this?
Old 04-11-2005, 11:59 AM
head suggestion
if you want to keep the costs down on the heads i bought a set of vortec heads with 600 lift springs and screw in studs from tri-state cylinder head for $500 including shipping. contact jim @1-800-270-0095 he may be able to help you out.
keith
Old 04-11-2005, 12:07 PM
Siggy_Freud's Avatar
Go with 64 cc heads. What brand/material you get will be dictated by your budget. If your Compression ratio is 9-9.5 you should be okay with Iron heads and running pump gas that is less than 92 octane.
Vortec heads would be the cheapest route as far as something that flows decent, but you'll have to change your intake as well. They need some work to be able to handle higher lift values. Might look into some Darts on ebay. Save up a few hundred more and pick up a decent set of heads. Dont be stingy when it comes to them .
Forget about destroking your engine. A 350 isn't that big to begin with, and in a street setup you'll never see the added RPM potential of a destroked engine. You'll end up with less power throughout your useable RPM range.
Save the 1.6 rollers for when you get some aftermarket heads.
Bringing history and technology together.
Old 04-11-2005, 01:27 PM
Hippie's Avatar
Last journal entry: HEI comparison.
That would be called a............. "327". The 302 Z-28's, 327's and 350's all use a 4" bore block the difference is in the stroke. I like 'em all but for a street motor I give the nod to the 350.
Old 04-13-2005, 11:45 AM
valve size
what do you think would work best with my combo? Should 1.94/1.50's do the job or would 2.02/1.60's work any better?
Old 04-13-2005, 01:48 PM
What heads are you putting on? Aftermarket? Stock? Give us the brand/specs for aftermarket or the casting numbers for stock.
Old 04-13-2005, 06:44 PM
I want to put on some aftermarket heads, most likely some Pro Topline's. I was looking at the Pro Torker's because they are in my price range and have mostly what I'm looking for. I want to run a 64cc head according to the previous guys to raise my compression. I have heard great things about Pro Topline so that's what I was looking for. If there is any other place or brand that has heads for around my price range (-$550) then I would definitely look into them. As for stock replacement heads, I don't really know what castings to look for. I don't really want to get vortec heads because I don't want to have to buy another intake, but if there's a great set for cheap enough I'll look at those too.
Another thing, how high of a compression ration can you go while still being able to run off of 87 octane gas?
Exhaust Suggestions REKRAP Garage - Tools 7 12-22-2004 08:10 PM
Suggestions on the best flux core wire? 357ford Body - Exterior 3 06-08-2004 11:23 AM
400sbc build-up suggestions Chevymetal Engine 7 10-18-2003 09:02 AM
81 el camino is almost ready to be painted need suggestions 81elcamino Body - Exterior 3 10-02-2003 01:34 PM
Tuning Suggestions for a .30 over 350 69malibu Hotrodders' Lounge 10 08-20-2002 07:57 PM
