motor rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2012, 03:31 PM
motor rebuild
this will be my first post. I have 84 caprice classic that i just brought im starting with the engine and want to built one i was thinking about a 383 stroker or go with a 400..what would i need for the build
Old 01-23-2012, 03:40 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Most will say the 400 even me. 383 pretty sweet though depends on which block you have on hand and what parts you already have also.
And how much is your budget for this build your gonna probably need a gear change and different converter. IMHO
Cole
Old 01-23-2012, 03:51 PM
re
Right now I'm starting from scratch. This will be my first build so i need help with literally everything from parts to know how
Old 01-23-2012, 07:28 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I would try to track down a vortec roller 1pc rear main seal block. Then get a scat cast steel crank and their rods with some hypereutectic pistons. Then invest in a good roller cam along with the factory vortec heads. Swap to a carbed intake and you should be sitting in the 400hp range no problem. I will be doing a build very similar to this next time I have some extra money kicking around. Im hoping around 425hp when im done with it though.
motor won't turn after rebuild?? 75_ranchero_429TJ Engine 6 10-06-2010 12:56 PM
Help on motor home sbc 350 rebuild Tea Two Engine 2 05-06-2007 04:28 PM
Synthetic Motor Oil In 454 Rebuild leejoy Engine 36 11-20-2006 02:34 PM
402 rebuild or crate motor rob68427 Introduce Yourself 2 12-18-2004 08:42 PM
Motor Rebuild 302 n00b Engine 2 09-30-2003 03:39 AM
