Motor Stumbles Under Load - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2007, 10:51 AM
GUYS I HAVE POSTED THIS A COUPLE OTF TIMES. I HAVE 350 IN A 88 CK1500. THE PROBLEM IS WHEN I TAKE OFF THE MOTOR HESITATES. WHEN IGIVE IT GAS IT SEEMS TO CLEAR UP. IF I CRUISE THROUGH A PARKING LOT I CAN FEEL THE MOTOR HESITTATE. IT ALSO SHUTTERS WHEN I'M CRUISING AROUND 30-40 MPH. BUT WHEN I GIVE T GAS IT CLEARS UP. THE MOTOR HESITATES WHEN IT IS AT OPERATING TEMP. DOESN'T DO IT WHEN IT COLD, HOWEVER WHEN I START IT IN THE MORNING THE IDLE FLUTTERS BUT IT CLEARS UP. I HAVE REPLACED CAP, WIRES, PLUGS, AND IGN MODULE. COULD IT BE THE EGR VALVE? NO CODES THROWN THOUGH? ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED.
Old 05-18-2007, 12:41 PM
tornado-tech's Avatar
The 1st thing I would check is your fuel pressure. Could be bad fuel filter.
Can't load pictures sword1812004 Hotrodders Site Suggestions and Help 0 10-19-2005 11:04 PM
Engine load vs Manifold Vac? JohnTN Engine 2 04-08-2005 09:22 AM
th350 leaking only under load justspeed Transmission - Rearend 6 10-31-2004 03:18 PM
th350 leaking only under load justspeed Transmission - Rearend 10 10-06-2004 09:03 PM
Oil pressure drop under load knizet Engine 9 01-13-2004 02:26 PM
