Ooops, sorry, forgot the rule about motor specs...
355 sbc, moderately built BDS 6-71 at 1:1 for 6# Comp "blower" roller hydraulic cam 2x Edelbrock 1405s (600 cfm) re-jetted for the blower MSD ignition (mag pick-up distro, 6AL box, Blaster II coil) Holley Blue electric fuel pump and regulator set a 5.5# Fram in-line cannister-type fuel filter ahead of the pump Motor has performed flawlessly since completion three years ago. |
Check your throttle linkage for hanging up. Your throttle return spring could be weak also.
I can't tell from the picture, how it is set up, and what kind of ends are on the linkage. Lube the points, and where the accelerator pumps attach. |
You don't have to pull the top off the Carbs. just the screw and plate covering the metering rods, and step up springs. You should be able to tell if a step up piston is stuck, by the amount of push from the spring as you remove the cover. If these are fine, start it up, or turn on your fuel pump, and look for excessive fuel out of the main jets. This could be something between the needle and seat.
For grins, remove a easy spark plug to get to, and check for a good spark. I have seen the center coil post on the inside of the distributor cap erode away. |
Life time honorary "Hosehead" membership, if you go to a Kim Mitchell beer party at the Kee to Bala. Then go fishin!
http://www.thekee.com/ |
LMAO! I'm a little tamer than that. We fly into Minaki and then float plane out to some remote lakes to the northwest. One Man, Moosehorn, Eagle Nest (actually in eastern Manitoba) and the like. No telephones, no cell phones, no intarwebz, no TV... just nature... it's spectacular in its lack of... people. Just nature... bald eagles, red-tail hawks, beavers, otters, black bears, moose, deer... and big frickin' fish!!
That's exactly what it was. Little shard of metal stuck in the pax side float valve of the front carb. Checked all the others plus all the metering rods just to be sure. We're good to go, except the spark plugs are majorly carboned up. Might be a good time to try a set of E3s.
| super rich mightey demon 750 blower carb | sheldonw | Engine | 10 | 01-28-2008 12:22 PM |
| Street Legal TV to Broadcast Video from NMCA Super Bowl Event at Route 66 | nmrajames | Hotrodders' Lounge | 0 | 07-26-2006 09:53 PM |
| Edelbrock.....super rich at idle?? Are the metering rods up? | wickster | Engine | 19 | 04-25-2005 09:14 AM |
| running super rich at idle??? | ocbaud | Engine | 4 | 11-21-2004 02:21 PM |
| Super 40 vs 50 Series Delta Flow | dannimo | Engine | 3 | 01-27-2004 03:16 PM |
