motor swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2013, 07:08 PM
motor swap
I have a 1950 Chrysler any put a sbc in one ? info a details would be appreciated ............
Old 02-23-2013, 07:41 PM
vinniekq2's Avatar
The chrysler guys would hate you.
Old 02-24-2013, 05:19 AM
anyone out their ?????? look how about a
318 with a 904 behind it anyone put one in a 1950 windsor
Old 02-24-2013, 10:38 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
PM sent.Ck that out.
Old 02-24-2013, 12:01 PM
455olds's Avatar
You will have to make the mounts for either engine, that and modify your transmission mount. It should not be that hard. Drop in the engine trans and see where to make your mounts, make templates and remove engine then build mounts. Make sure you have the engine/trans at the correct angles as well.
The Following User Says Thank You to 455olds For This Useful Post:
brent7727 (02-24-2013)
Old 02-24-2013, 05:31 PM
JeffB's Avatar
A 318-360 is a better fit around the steering column area and there is a kit available:Butch's Cool Stuff42/52 Ply, 41/52 Dod SB Chrys Eng/Trans mt kit 2188CP $299
81 cutlass motor swap for a 350 chevy motor metro0911 Engine 2 02-24-2012 11:55 PM
Motor Swap KTPARISH Engine 5 02-20-2012 01:06 PM
motor swap trlblzr Engine 0 05-25-2006 05:24 PM
motor swap larry's66 Hotrodders' Lounge 10 08-31-2002 09:04 PM
motor swap 54 Buick Engine 4 09-16-2001 08:53 AM
