motor/tranny suppose to be level? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2013, 05:06 PM
31ROC's Avatar
Getting closer to finishing the auto-over-4 speed conversion. Fabbing up a new tranny crossmember, and wondering if the motor is suppose to be level? Maybe motor & tranny pointing down a tad?
Previously the 700R4 was in a position where the driveshaft fit through a "blow-proof" ring which is welded to the frame. Now, with the Muncie, that ring appears to be way to high for the driveshaft......Guess I can always cut and move that....(is it needed?)
Oh...forgot to mention this is a 31 Model A coupe.....
Old 03-01-2013, 05:26 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
The intake should be level where the carb bolts on.
I believe it's about 3*.
Old 03-01-2013, 05:36 PM
bigdog7373's Avatar
Of course it's fast
x2...........
Old 03-01-2013, 05:40 PM
31ROC's Avatar
so if the carb is level, will that make the motor/tranny point downward the 3*?
is there any harm in the carb not being level? ie: bigger tires making the car rake more?
Old 03-01-2013, 05:42 PM
bigdog7373's Avatar
Of course it's fast
Fuel won't be distributed evenly though the intake. If its leaning way back the rear 4 cylinders will run rich and the front 4 run lean. Vice versa if it's leaning forward.
Old 03-01-2013, 05:50 PM
31ROC's Avatar
wow...never crossed my mind....but i guess a little tilt wont hurt....I thought the tailshaft/driveshaft being fairly level was important....and wanted to use the existing "ring" the driveshaft use to go through, but I am a lot lower now. Never figured the 700R4 would be that much higher
Old 03-01-2013, 07:56 PM
bigdog7373's Avatar
Of course it's fast
Seems weird it won't line up. Maybe cause the the input and output of the muncie are in line and the 700r4 aren't.. That's all i can think of
Old 03-02-2013, 04:34 AM
31ROC's Avatar
could be...I should have made note of how high the 700r4 was mounted and noticed the angle of the yoke at the rear of the tranny before I removed it, I DO know that the rear support member is now about 1 1/2 inches lower than it was, so there's the difference I suppose....
Old 03-02-2013, 04:51 AM
poncho62's Avatar
Wiki Edits: 5
There is not a pool of gas in the intake....The carb mixes the gas with the air, so it will be even whether one end is higher or lower. You want the carb more or less level so that the fuel bowls sit level.
Old 03-02-2013, 05:04 AM
31ROC's Avatar
thanks........I thought that too, but wasnt sure....seems like most cars/rods the motor appears to be pointing upwards slightly in front.
Old 03-02-2013, 05:24 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
What degrees at the yoke are you talking about now??. What degrees is the rear end going to end up??.
I do tire of second guessing O/P's,but not for nothing if it where me going to stick shift,I would have gone to a Tremtec 5 speed to get the best of two worlds.
Old 03-02-2013, 05:29 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Here's a guide to check your drive line angles.
Old 03-02-2013, 07:12 AM
spinn's Avatar
Big dog , must only drive around on level roads. It will effect the floats, and bowls volume .
Old 03-02-2013, 09:07 AM
31ROC's Avatar
why second guess at all? dont do 5 speeds, not old school.......
What to level, motor or trans? 49panelsteven Engine 9 01-16-2012 07:02 AM
Pan level VS stick level th350 sooper Transmission - Rearend 5 07-03-2010 04:50 PM
My Introduction, I suppose Billy Paul Body - Exterior 1 09-19-2006 11:10 AM
Better late than never I suppose. mosstrooper Off-Topic 9 02-11-2006 03:35 AM
Is epoxy sealer suppose to be shiny? FrankR Body - Exterior 1 09-25-2005 09:03 AM
