motor won't turn after rebuild?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2010, 10:48 AM
75_ranchero_429TJ's Avatar
we rebuilt a motor put everything together and once we turned it without the pulley, it turns but once we installed the pulley it won't budge!!!
What may be wrong? PLEASE HELP!!!
Old 10-06-2010, 10:50 AM
engineczar's Avatar
Bolts too long bottoming out on the timing cover behind the balancer?
BSE Racing Engines
Old 10-06-2010, 11:03 AM
no belts are on yet
Old 10-06-2010, 11:09 AM
I'm sorry, I read belts. Okay, I'll try to use shorter bolt
Old 10-06-2010, 11:12 AM
okay, i used the original bolt plus even used 2 washers.....still the same
Old 10-06-2010, 12:24 PM
68NovaSS's Avatar
Wiki Edits: 9
Is it a new crank? New damper? I'd pull the damper back a little bit and try to turn it. If the bolts aren't hitting the timing cover like Czar says, maybe the dampers bottoming against the #1 main webbing?
Old 10-06-2010, 12:56 PM
the original pulley broke and we were able to find one in the junk yard. same motor but different year. it went in and aligned but won't turn the motor. just pulled it right now and found out that it's different by a hair.
probably take it to a machine shop or put a washer.
Voltage reduction at turn signal swith? cboy Electrical 10 05-13-2010 05:57 PM
Timing a 350 oke02206 Engine 1 08-03-2008 01:27 PM
69 mustang turn signals dont work GT350 Electrical 3 02-22-2008 03:55 PM
turn signal problem jimang22 Electrical 1 01-03-2008 12:09 PM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 06:23 PM
