motorcycle oil in my motor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2005, 06:45 PM
this sounds nuts but ive heard this recently. this guy my brother knows has put motor cycle oil ( yamalube) in his 350. he says it works great and is good for older motors. ive heard alot of tricks in my day but never this! lol i guess it would work but how would it be better or worse! im unsure of motorcycle oil weight or compatability with a water cooled motor. i have heard people using motorcycle oil in air compressers due to them being air cooled as well. whats youre thought on this yamalube tune up lol?
Old 08-18-2005, 07:07 PM
Wiki Edits: 31
I'm not shure of it's weight, if it is equivilant to 5w30 or 10w30 than I guess it wouldn't hurt anything but, I think it wouldn't do a thing. Seems like motorcycle oil is thinner. bottom line, don't use it.
Old 08-18-2005, 07:16 PM
lol trust me im not going to use it im curious if anyone has done this or heard of it.
Old 08-18-2005, 07:56 PM
poncho62's Avatar
Wiki Edits: 5
It may not hurt anything, but it's not going to help cure anything either.....what was the claimed improvement with this oil?
Old 08-18-2005, 08:05 PM
he said the car had alot of miles on it and had a small tap to it like a rod or something and it doesnt tap with the yamahalube. he says the oil doesnt break down as quick as conventional oil so it cushions the motor like the that lucas oil additive. is motorcycle oil thicker than regular oil? and do motorcycles run hotter than cars? im just asking, again im not going to put this in my car lol! just curious about stupid things people do but who knows maybe theres something more here? you tell me
Old 08-18-2005, 08:06 PM
Poncho i dont think it will cure anything either lol
Old 08-18-2005, 08:12 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The YamaLube that I use in my 4 stroke outboard motor is a full synthetic 10W30. I don't know about the YamaLube motorcycle oil though.
Old 08-19-2005, 12:30 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
motorcycle oil in car
stupidsuckers.com sells the 1 quart cans of Liquid Overhaul for only $ 29.95 plus shipping...
Old 08-19-2005, 11:07 AM
Most all motorcycles share the same oil for the engine as well as the gearbox and clutch. The additive package is stiffened to increase the shear strength to hold vescosity better. That's the main difference with MC oil.
It is not thinner.
Old 08-19-2005, 06:59 PM
Specifically labeled M/C oil is probably designed for air cooled engines which are subject to fast changing extremes in temperatures and tolerances. We used to use Aeroshell in our old Harleys--regular auto oil seeped out all over and burned up quick. (Newer bikes with better technolgy don't suffer this problem as much any more.)
By the way--hello, my first post here. I wanted to respond to this, so I finally joined up.
John
Old 08-20-2005, 12:45 AM
Welcome to the board JPhil. In the past air cooled was the norm. Now we bomb around on 160 WHP liquid cooled fuel injected monsters. Harleys are different for sure, with the exception of the V Rod. Two issues 90% of the motorcycle formulations have to deal with, other than basic lubrication. The shear forces of the gearbox and the wet, multi-plate clutches. These add packages differ on MC specific oils versus conventional motor oil.
new rebuild no oil getting to top end. Edelbrock350chev Engine 11 12-29-2004 05:03 PM
Motor oil in rearend in a pinch unstable Transmission - Rearend 9 08-13-2004 08:34 PM
walmart super tech motor oil??? Blown72Camaro Engine 7 05-18-2004 06:42 PM
oil leak when adjusting timing?? Trav Engine 14 11-15-2003 11:55 AM
Take My Used Motor Oil, Please! lakeroadster Hotrodders' Lounge 8 04-25-2002 08:24 AM
