motorized doors???? help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2006, 09:48 AM
TexasDan's Avatar
I have a panel that is located in the back of my truck. I want the panel door to lift out then up. I would like for this to be done by pushing a button. Here is the web link to a picture of what I'm doing. It is picture 12 and 13 down the page.
www.ltw.net/Buildup11.html
Any ideas or hints Please!!
Old 09-26-2006, 07:55 PM
Kruzin Karl
Are you trying to do one hinged swinging motion, or two separate motions, as in, out horizontally, and then up vertically?
Old 09-27-2006, 09:14 AM
TexasDan's Avatar
I want it to pull out then go up. I'll do either, which ever can be done. I figured out how to do it with a single hinge but I'll have to use small gas shocks to lift it. But it will be a bear to push down. My 11 year old daughter will have to be able to puch it down from the seated position.
Old 09-27-2006, 12:06 PM
powerrodsmike's Avatar
Wiki Edits: 161
Instead of a gas spring you could use a linear actuator. they are pricey, (175.00 and up), but one unit would do it and you could activate it with a button. Check Autoloc or Balls rod and custom.
I have seen folks use a electric window regulator for lifting and closing panels like that . Sounds like a good reason to go junkyard dubbin to me
Later,
mikey
BE different....ACT normal.
Old 09-27-2006, 12:47 PM
TexasDan's Avatar
I thought about the actuator, I found one for less than $100. http://www.firgelliauto.com/default.php?cPath=74 I plan to use one of these for running boards that will drop down.
I'm going to use the power window regulator to open and close the panel for the front. I spent about 2 hours last night making it work. I had some old power regulators that I'm not going to use, so I desided to make them fit the project. I'll have pictures soon on the web site.
Thanks for all your help.
Old 09-27-2006, 02:04 PM
DanTwoLakes's Avatar
Wiki Edits: 22
A linear actuator would be the best way to go about it. Check with bearing distributors that sell Warner Electric products. You don't need a gigantic expensive actuator to do what you want.
Good luck.
Old 09-27-2006, 02:10 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Try Surplus Center -lowest prices around!
www.surpluscenter.com
Need some suggestions on fixing up these doors Ripped Body - Exterior 1 05-09-2006 05:52 AM
Model T doors KA67_72 Body - Exterior 2 08-07-2004 08:36 PM
1930 Coupe Doors? SuperFrog Body - Exterior 3 03-06-2004 04:53 AM
4dr suicide doors along diagonal? Nanook Body - Exterior 0 01-09-2004 10:26 AM
Where are the doors? 26trackt Body - Exterior 0 12-03-2002 03:34 PM
