Mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2005, 12:49 AM
TWOPLYM's Avatar
New Member
Mount
Hey Im In The Process Of Rodding A 48 Plymouth I Have Dropped A 305 Chev With A 350 Trans Now I Romeved The Stock Trans Mount Cuase I Coulnt Use It I Could Have Used A Tubular Mount But I Also Upgraded My Master Brake Cylinder Which I Put In The Stocl Location Now The Problem Is I Coulnt Go Straight Across With The Tranny Mount Cause The Cylinder Is Smack In The Middle Should I Relocate The Cylinder Of Fab A Mount I Have Seen Some With A Very Long Rod From The Pedeal To The Brake Piston But Were Can I Get One Any Suggestions
Old 07-08-2005, 05:38 AM
302 Z28's Avatar
I would relocate the MC. The actuation rod is easily fabricated using some heavy wall 1/2" or 3/4" tubing. You can purchase weld in bungs for each end of the rod through several suppliers like Speedway or Jegs.
Vince
Pontiac 3400 serpentine belt/motor mount problem ChevelleSS_LS6 Engine 3 06-15-2005 04:15 PM
Do SBC and BBC mount in the same position? 70bird Engine 3 11-06-2004 08:16 PM
oil filter mount bypass valve? fireforsin Engine 3 10-14-2004 05:18 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 04:52 PM
front sway bar mount location fire power Suspension - Brakes - Steering 2 05-17-2003 08:10 AM
