Mount shocks upside down? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2012, 08:30 AM
Brian Morency's Avatar
Hauling A55 BURNING GASS!!!
Last journal entry: bros car
By mounting my rear shocks upside down will that help get better traction?
Old 03-31-2012, 08:39 AM
S10xGN's Avatar
Gotta love a turbo!
Why on earth would you think that? It won't do anything beneficial and may even ruin them by virtue of them being in the wrong orientation.
Russ
Old 03-31-2012, 08:57 AM
LATECH's Avatar
Nope. Shocks will likely loose there prime and quit working , even gas shocks which are self priming (not allways the case) would probably quit working.
The action of collapse and rebound is the same if the shock is right side up or not.The shock collapses easy and is slow to extend( dampening the rebound) . The action will be the same if the shoch is right side up or not, at least untill it malfunctions.
Stickier tires would be a way to go. Treadwear ratings that have a higher numer are a harder compound, and dont "stick" to the road as well as a tire with a lower treadwear number.But they last longer. Its a trade off.
traction bars may be a better alternative.
Old 03-31-2012, 09:38 PM
I heard some shocks could be. And that it had something to do with unsprung weight.
Old 03-31-2012, 10:19 PM
New Member
Old 03-31-2012, 10:25 PM
Northstar T's Avatar
Gone sailing
Yes. but only in reverse gear.
Russ
Welding upside down????? tinman386 Garage - Tools 51 02-26-2009 10:55 AM
Upside down Headers pi71 Engine 1 08-04-2008 05:53 PM
Vega box upside down? cboy Suspension - Brakes - Steering 17 07-18-2007 08:32 AM
Plug Welds upside down pschana Body - Exterior 11 09-20-2004 08:28 PM
welding upside down... autocol Body - Exterior 9 08-19-2003 12:02 PM
