mounting diff to 1950 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2007, 05:26 AM
71corvette's Avatar
I want to put a ford 9 inch rear end under my 1950 chevy pickup. what do I need to do to mount it? do I need to change the spring mounts? where can I get the parts? I know I will need to narrow the housing. I plan on building a strong small block so i want a stout rear end.
Old 12-19-2007, 05:35 AM
31 five window
Last journal entry: Moving along with patch panels.
Most leaf spring rear ends mount centered over the rear spring center bolts. This is not so with yours.It is mounted behind the center bolts because it has a torque tube type rear you can make your own offset rear end saddles to solve this problem or change location off springs or go to different type of rear suspension .Look and see what I am talking about then get back to me if you have more ???
Old 12-19-2007, 05:54 AM
opinionated old fart
Last journal entry: Sheetmetal
this is how I mounted mine, it is a FatMan Fab kit
Larry
Old 12-19-2007, 06:32 AM
71corvette's Avatar
Larry
I like that. could you also go with an air ride suspension ?
Old 12-19-2007, 08:41 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
Yes you can.
Old 12-19-2007, 12:07 PM
NOT a 50 truck ... ( 1932 Ford chassis ) but the principal is the same ...
4 link riding on coils ... like a late 60's Chevelle
As for using your original springs ... I would remove a few leafs and then redrill the locating pin in the correct location. OR ... RB's Obsolete has a kit to install later open drive line rear ends under your truck ...
Go here for the kit ...
http://www.rbsobsolete.com/product.a...7&l1=17657&l2=
RB's also has a bolt in Mustang II IFS kit for your truck.
It is here ...
http://www.rbsobsolete.com/product.a...4&l1=17224&l2=
Adapting ford engine to chevy truck. 68novafan Engine 9 10-11-2006 02:31 PM
looking for a pic - the Navarro (?) families 68/69 chevy truck lowROLLERchevy Hotrodders' Lounge 0 10-03-2006 03:24 AM
429 caddy moter in 1950 chevy truck ?? cool running Engine 3 05-20-2004 05:45 AM
spring selection for a 1950 chevy truck solowookie Suspension - Brakes - Steering 4 03-19-2002 10:21 PM
