-   -   Mounting Engine (http://www.hotrodders.com/forum/mounting-engine-222582.html)
scottyd 08-05-2012 04:33 PM
Mounting Engine
Im mounting an engine for the first time and need some tips like how to line everything up,should the engine be level?,tips on welding on motor mounts. Any good sites out there with help with this kinda stuff any tips would be much apprieciated
S10 Racer 08-05-2012 06:07 PM
It depends on what motor you're talking about. Is it a carb'd motor or FI? If carb'd, you need to mount the motor where the carb base of the intake is level. This will usually make your motor tilt back slightly but the objective is to keep the carb level, not the motor.
RWENUTS 08-06-2012 07:36 AM
What car?
What frame?
Lots of options!!
ap72 08-06-2012 09:20 AM
you need to watch your tailshaft alignment. It need to be parallel to your pinion, for this reason mounting your engine and trans together is usually the easiest approach. Other than that as far back and low as you can get it is usually best for handeling.
scottyd 08-12-2012 02:20 PM
Its a 350 small block
