Mounting Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2012, 04:33 PM
scottyd's Avatar
scottyd's 51Prefect
Last journal entry: Exhaust Manifolds and Water Pump
Mounting Engine
Im mounting an engine for the first time and need some tips like how to line everything up,should the engine be level?,tips on welding on motor mounts. Any good sites out there with help with this kinda stuff any tips would be much apprieciated
Old 08-05-2012, 06:07 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
It depends on what motor you're talking about. Is it a carb'd motor or FI? If carb'd, you need to mount the motor where the carb base of the intake is level. This will usually make your motor tilt back slightly but the objective is to keep the carb level, not the motor.
The Following User Says Thank You to S10 Racer For This Useful Post:
scottyd (08-12-2012)
Old 08-06-2012, 07:36 AM
RWENUTS's Avatar
What car?
What frame?
Lots of options!!
Old 08-06-2012, 09:20 AM
Banned
you need to watch your tailshaft alignment. It need to be parallel to your pinion, for this reason mounting your engine and trans together is usually the easiest approach. Other than that as far back and low as you can get it is usually best for handeling.
The Following User Says Thank You to ap72 For This Useful Post:
Old 08-12-2012, 02:20 PM
scottyd's Avatar
scottyd's 51Prefect
Its a 350 small block
engine mounting in frame gufnstuf General Rodding Tech 24 09-08-2011 02:44 PM
Engine mounting Jimatruckin Engine 3 04-11-2010 03:09 PM
Mounting my engine in the chassis Quarter Flash Hotrodders' Lounge 3 02-09-2007 08:12 AM
engine mounting plates 2Cammer Hotrodding Basics 6 12-20-2005 05:53 AM
Engine mounting Dutchman Engine 2 08-25-2003 02:12 AM
