mounting exterior mirrors to doors - '65 chevy truck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2005, 05:25 AM
Socket Breaker
Last journal entry: My website for my '65 chevy c10 lwb step
Ok, first off, I am rather ignorant about this sort of thing, but I'll try to explain what I want to do.
This is my truck... a '65 c10 chevy lwb stepside.
The white painted mirrors on the right in the above photo are the ones I want to mount up to my doors.
The above picture shows the situation that is underneath the mirror brackets that are currently on there.
From what little I know, welding is the best way to fill in these holes... and from what I have read or been told, after being welded... that welded part will be harder than the surrounding sheetmetal... so it would be better to mount up the mirrors like I need them before having them welded, right?
I have never mounted up mirrors on a vehcile before, so what do I need to make sure of or watch out for?
Thanks.
-W
Old 08-21-2005, 05:17 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Well Nuts
Thanks.
-W
I can't comment on the welding thing, but I imagine that it should be safe to drill the new ones first.
Be sure to us "well" nuts in the newly drilled holes so that you have something secure to bolt to.
I shake my head when I see people mounting mirrors to panels with sheet metal or self-tapping screws. These are usually the same guys that have their mirrors falling out of the rusty holes in a few years.
Style is a matter of choice, but I rather prefer the "flag" style that you have now. Are you replacing them because of vibration? If so, try a set of early-80's Ford F150 mirrors like I did. They fit reasonably well, with some minor bending of the brackets, and are "rock steady" on my 66 GMC.
I'm attaching a couple of pic's of them. Open the 2nd one and zoom in to 100% for a good look.
P.S. My original mirror was a really small round one that mounted on that triangular "plug". This time, that will be filled permanently!
ID:	6528   Click image for larger version
Old 08-21-2005, 05:26 PM
steve t's Avatar
ex biker, now hotrodder
i like the chorme ones that are on it, but it not my truck
Old 08-21-2005, 07:37 PM
I agree, the chrome ones that are on now are much better looking IMO.
Mock up your new mirrors and mark the holes to find out if they fall into the same area as the exhisting holes. Drill the new holes then have the others welded up. Use a good sealant around the well nuts and hardware to keep moisture out. Stip calk, dumdum, plumber's putty, roofing tar or anything similar will work to keep moisture out of the fastener area. Bob
Old 08-22-2005, 02:25 AM
Socket Breaker
The mirrors that are on it are broke and I'm 'over them' so to speak.
I like the big honkin' mirror look... . I bought the big mirrors off a guy who hot rodded his '64 chevy c10.
I think only one hole 'sorta almost kinda' lines up last time I messed with it.
I was also wondering, should I find some kinda material to go between the bracket mount and the paint/panel of the door or no?
"Well nuts"... what are those exactly?
I've read and been told I need to have something back there to spread the load out, instead of just the bolt... makes sense to me. I've read various things, from using 'fender washers(no idea where to get them)' to puttin' a piece of sheetmetal back there for the nuts to go through.
Thanks very much for the replies and suggestions.
-W
Old 08-22-2005, 05:15 AM
Well nuts are threaded inserts you install in the door skin, some are rubber and others are alluminum. I guess you wouldn't need to use the well nuts if you made a plastic gasket and used stainless bolts and nuts. You could also make a reinforcing plate to go inside the door-this would eliminate some doorskin flex and possible cracking.
Old 08-22-2005, 08:49 AM
66GMC's Avatar
Here's a picture of the ones that we (NAPA) sell.
To be honest, I like the Ford ones (aluminum) better.
Perhaps a nylon washer between the mirror arm and the door panel will prevent rubbing?
Old 08-23-2005, 03:30 AM
Socket Breaker
66gmc - thanks for the picture of the well nuts.
Thanks again to everyone's replies.
Ya'll have given me some more things and options to think about, which is what I was looking for as I don't want to just start drillin' holes.
Any tips on drilling sheet metal? The door will be mounted and so forth...
As I write this post I'm sitting here thinking that I have not done that(drilled sheet metal) before... hmn.
I've drilled wood, concrete, metal washers, metal brackets...
Thanks.
As ya'll can tell I need all the tips I can get.
-W
Old 08-23-2005, 02:08 PM
66GMC's Avatar
Here's how I would do that:
-W
1.) Use a large, say 1-1/2" or 2" square piece of masking tape close to where you'll be drilling.
2.) Mark the locations of the spot to be drilled on the masking tape, being careful to mark the center of the hole as exactly as you can.
3.) Use a center punch to "dimple" the center of the hole. This will help to steady the drill bit when it starts turning and prevent it from "walking".
4.) Use either a high-speed or cobalt drill bit as this is what you need for drilling metal. You'll want to select a bit just big enough that the well nut fits fairly tight.
4A.) Actually, drilling the initial hole with a purposely smaller bit, followed by the correctly sized bit might be a good idea.
5.) After drilling the hole, remove the masking tape and have a look for any sharp steel edges that may protrude above the hole. If there are any, you should remove them. The easiest way is to clean it up with a round file, or take the next larger bit and LIGHTLY chamfer the edge of the hole.
6.) As badbob suggest earlier, use some kind of sealant putty and install the well-nut.
If you're using the aluminum type -- they need to be pre-crimped before bolting on the mirror. Using a 1-1/2" long bolt, nut, and flat-washer that is the same thread diameter as the well-nut (in that order), screw this assembled hardware into the well nut. Hold the bolt-head with one wrench and tighten the nut with another. This will cause the well-nut to "crush" and swell out behind the sheet metal and tighten itself in the hole. After crushing the well nut, you'll have a permanently mounted threaded hole to mount your mirror to.
HTH,
Don
Old 08-24-2005, 02:51 AM
Socket Breaker
66gmc - thanks - that is good info, thanks for taking the time to type it up and post it.
I had most of it but the maskin' tape bit...
I must be on the right track.
-W
Old 02-27-2006, 03:40 PM
Socket Breaker
latest photos(02/26/2006):
http://woogeroo.home.mindspring.com/.../02262006.html
up close mirror photos(02/11/2006):
http://woogeroo.home.mindspring.com/.../02112006.html
Thanks for tips and advice.
-W
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
1951 Chevy Truck chevblazk5 Suspension - Brakes - Steering 3 01-26-2006 08:27 PM
Graft a pontiac engine into a 63 chevy truck Raphyel Engine 10 09-02-2004 01:19 PM
69 chevy truck front end change dragn azz Suspension - Brakes - Steering 4 07-23-2003 01:16 AM
