Mounting ideas - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2013, 05:09 PM
Babyburr's Avatar
Mounting ideas
Well, I am in the process of building a Fiberglass T-Bucket with a flat wood floor. Most folks just make a seat out of plywood with foam for cushion. I want to be more comfortable than that, so I'm using the middle bench seat out of a Dodge Caravan. I cut out 4 inches and it fits very well in the bucket.
Now, I need some ideas on mounting it to the floor. To get the most leg room possible, it needs to be mounted directly to the floor. No brackets attached to seat, and then to floor. Only thing I have come up with is to bolt two metal straps to the bottom at the front of the seat, and then to the floor. I can not figure out how to secure the rear of the seat to the floor.
Any ideas???
The straps are long enough, so I don't think the seat would come up in the back when braking.
Thanks
Old 08-17-2013, 07:06 PM
Cape Cod Bob's Avatar
Make a bracket to mount to the body at the back of the bucket that has like an upside down J shape to it. Add a U shaped bracket to the back of the seat close to the bottom and lined up with the bucket bracket. Make it so you have to tip the front of the seat up to fit under the bucket bracket and when you lay the seat down into place it is hooked under the J bracket. Then just screw the front to the straps as you planned.
This would be similar to the way back seate s were in older cars,
How 'bout some pics?
Old 08-17-2013, 09:12 PM
Babyburr's Avatar
Here is the seat
Old 08-17-2013, 09:13 PM
Babyburr's Avatar
Here is the car
Old 08-17-2013, 09:29 PM
life is a temporary assignment
Look's like you have four flatbars welded already to the bottom of the seat, Drill them out for 3/8 bolts.. Put them in from the top letting them stick out the bottom.. Put a tack on the head to the flatbar,, Drill four holes in the floor and bolt them from the bottom...
Here's one I'm finishing up on..
ID:	76749   Click image for larger version
Old 08-17-2013, 09:51 PM
Babyburr's Avatar
Great ideas, fellas. Thanks a lot.
Sweet lookin Bucket, for sure!
The Following User Says Thank You to Babyburr For This Useful Post:
NEW INTERIORS (08-25-2013)
Old 08-24-2013, 08:49 PM
Babyburr's Avatar
[QUOTE=NEW INTERIORS;1705975]Look's like you have four flatbars welded already to the bottom of the seat, Drill them out for 3/8 bolts.. Put them in from the top letting them stick out the bottom.. Put a tack on the head to the flatbar,, Drill four holes in the floor and bolt them from the bottom...
Guess it took another set of eyeballs to look at my seat. Those flat bars on the bottom of the frame worked perfectly!
Thanks again for the assist.
Old 08-24-2013, 10:26 PM
Banned
that looks good but remember one thing. more padding means you sit higher in the rod instead of being in it. so you will be hit by the wind ,bugs, road c**p . And so on. half a head over the windshield looks silly to me every time i see it. i sit in mine, not on it. just something to think about.
Old 08-25-2013, 10:25 AM
Babyburr's Avatar
Yes sir, you are right. When I get cushions for the frame I will make them a lot thinner than the stock ones that came with the seat frame. I don't like that goofy look of sitting on top of the car either.
Old 08-25-2013, 10:58 AM
I think I'd make sure that the bolts holding the seats attached to something besides your plywood floor. If they don't sit over the frame rails I'd weld in a couple of cross pieces for the seat to bolt to.
Randy what do you attach your seats to?
BB
Old 08-25-2013, 02:37 PM
BB
His floor is glassed in.. So he can go right through the plywood floor.. No problem with that... I wouldn't use seat belt's in a t anyway... You flip it and you find out fast why not to wear them..
As far as my seats... It depends on what car it is.... If it's a glass car and the floor is done right.. Through the floor it goes.... I don't worry about having a plate welded to the frame... If that car get's in a bad enough wreak and the body comes off the frame... I want to stay in the body... I don't want my seat belt bolted to the frame...
And if your talking about the T-Bucket I built... The back of the seat is a one piece unit he built,,, It fit's tight in the car and holds it's self in place very well..Tight fit.. The bottom of the seat is the same way.. It is removable...
The only wood glassed into this body is the firewall and floor,,, Under the seat is the fuse box and storage...
All the interior in this car can be removed if need be..
And you don't have to make your seat thick,, Just use high density foam,,
ID:	77490   Click image for larger version
Old 08-25-2013, 03:03 PM
Babyburr's Avatar
Those are my thoughts, also. These T-Buckets are just a little bit safer than a motorcycle and I have been riding motorcycles for years. My T is registered and tagged antique and I don't have to have belts and I'm glad I don't. I know some guys have attached their belts to the frame. Bad news for sure if the body flies off in a wreck. I'm just bolting the seat to my floor.
Old 08-26-2013, 11:09 PM
wow this looks beautifull.
you guys are really creative.
i tried designing the interiors of my car and the results were disasterous
___________________
travel with me
India Tour
Rajasthan Tour
Old 09-08-2013, 05:13 PM
Babyburr's Avatar
Well, got it covered and mounted. Thanks NewInteriors for you help.
NEW INTERIORS (09-09-2013)
Old 09-08-2013, 05:32 PM
Looks good!
BB
The Following User Says Thank You to boothboy For This Useful Post:
Babyburr (05-26-2014)
ideas on fixing warpage on vette bumper near mounting area tech69 Body - Exterior 10 01-25-2013 02:01 PM
need some coil mounting ideas 37 ford org flathead 37ford4dr Electrical 1 03-04-2011 08:50 PM
Mounting T-5 in 31chevy Transmission - Rearend 2 04-22-2008 04:28 PM
Mounting outside guages, Any ideas?? blacklotus General Rodding Tech 4 10-20-2007 08:21 PM
column mounting help APalusky Suspension - Brakes - Steering 5 10-03-2007 05:49 PM
