Mounting model A radiator. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2012, 07:37 AM
31 five window
Last journal entry: grill and rear end
I would like some input from experienced model A Ford builders. When you mount the bottom of the radiator to the crossmember do you use the stock hardware or being it is a modified Hot Rod do you do something different?Thanks.
Old 05-16-2012, 09:12 AM
Frisco's Avatar
Glad To Be Here
The stock mounting is best. It allows for some movement of the radiator caused by vibration. This helps prevent the mounting tabs from cracking. The castellated nut is tightened down to slightly compress the spring and then the cotter key is installed to prevent the nut from backing off. Be sure to install the pad first.
Old 05-16-2012, 09:46 AM
31 five window
Thanks Frisco. I thought you would be the one to answer. I have worked mostly on tri fives and a few original model A's so I know how to do it stock,but with your experience I wanted to make sure there wasn't some hotrod trick that was better.Thanks again.
Old 05-16-2012, 10:50 AM
Irelands child's Avatar
This is the original way along with the top mounted support rods to the firewall:
The castellated nut is below the bracket on mine
Irelands child
Old 05-16-2012, 12:47 PM
And of course if you want to modernize it you can use a lock nut and skip the castle nut and cotter pin.
Old 05-18-2012, 07:02 AM
31 five window
Yes I know. There is a Stainless steel version offered and it comes with nylon locking nuts.Thanks.
Old 05-18-2012, 07:06 AM
31 five window
Thanks for the images.Where did you get the support rods and are they stainless? Also how about a couple pics of your firewall top and bottom.My car was butchered and am trying to decide how I am going to make the firewall and front bottom mounts.
Mounting electric fan to radiator Babyburr Electrical 11 06-04-2011 04:47 PM
Mounting a radiator Longboard Hotrodding Basics 16 04-26-2010 09:10 AM
Radiator mounting Blackhauk90 Engine 2 02-23-2009 04:14 PM
radiator mounting michael cook Engine 2 01-07-2009 08:38 AM
Radiator Mounting donwesen Hotrodding Basics 1 12-12-2006 12:39 AM
