Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mounting Trans Cooler
Old 03-17-2009, 02:05 PM
kleen56's Avatar
kleen56 kleen56 is offline
I mounted mine on the inside frame rail under the vehicle. If your using a aftermarket trans cooler, it is cooled by air, you don't need that much air to make the cooler work. If you mount it underneath, you make sure it's not in a position where rocks etc can hit it, but air will.
