Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mounting Trans Cooler
Old 04-11-2009, 07:47 PM
Mike H Mike H is offline
Originally Posted by chevytruck33
you dont want to mount your tranny cooler on or to your radiator beacuse the heat from the radiator will transfer to the trans cooler mount it on the a/c condenser
Also the condenser is hotter most times than the radiator is 250+ psi on the high side is pretty common with 134 and that dictates to 200+ degrees on the trans cooler as well.
I have run them under the car, in the radiator on door cars and under the radiator above the trans on my Mullis dragster and have never had issues with any overheating transmissions.
