Mounting Trans Cooler - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2009, 01:59 PM
Last journal entry: It's getting there
I have a '41 Chevy Coupe with a 350sbc and a 700R4. Trying to decide where to mount a transmission cooler. The radiator is small and I don't want to cover up any more of the fins than I have to at this point.
I will be adding A/C so I'll have enough air restrictions the way it is without adding more.
Any suggestions ?
Thanx in advance
Old 03-17-2009, 03:05 PM
kleen56's Avatar
I mounted mine on the inside frame rail under the vehicle. If your using a aftermarket trans cooler, it is cooled by air, you don't need that much air to make the cooler work. If you mount it underneath, you make sure it's not in a position where rocks etc can hit it, but air will.
Old 03-17-2009, 03:50 PM
you dont want to mount your tranny cooler on or to your radiator beacuse the heat from the radiator will transfer to the trans cooler mount it on the a/c condenser
Old 04-11-2009, 07:19 PM
user151's Avatar
Actually you can - remember, the stock transmission cooler is INSIDE the radiator.
Old 04-11-2009, 07:47 PM
Also the condenser is hotter most times than the radiator is 250+ psi on the high side is pretty common with 134 and that dictates to 200+ degrees on the trans cooler as well.
I have run them under the car, in the radiator on door cars and under the radiator above the trans on my Mullis dragster and have never had issues with any overheating transmissions.
Trans cooler location scapegoat Transmission - Rearend 7 04-22-2008 11:02 AM
External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC Cousin_Joe Transmission - Rearend 1 02-27-2008 10:10 AM
Trans cooler butch27 Transmission - Rearend 3 09-28-2007 03:35 PM
patching up trans cooler 53LEDSLED General Rodding Tech 6 07-25-2006 01:24 AM
????about putting a trans cooler on??? Robbie Transmission - Rearend 1 04-17-2004 09:53 PM
