Mounting Windage Tray - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2006, 04:39 PM
Has anyone gotten away with mounting a Milodon or similiar windage tray using only 4 bolts (3 main cap posts and the oil pump bolt ) as opposed to 6 as it designed to mount with? This is a 4 bolt SBC 350 and I'm using the stock main cap bolts. The block used to have a stock windage tray where only 3 of the cap bolts and oil pump bolt supported it. Would it be a bad idea to not have the front of the new Milodon tray bolted down? The only thing I can think of being a problem is excessive vibration, but the tray seems to be sufficiently stiff the way it is. Has anyone installed a tray this way?
Thanks
Old 05-06-2006, 06:26 PM
Old does not mean dumb
Not a good idea. Even with all the bolts I have seen "Nasty" vibration cracks running from all the mounting holes...
Old 05-06-2006, 10:00 PM
wow, I really appreciate your response. I was about to do a final install of the oil pan.
Windage tray clearance blacklotus Engine 3 04-03-2005 09:10 PM
windage tray clearence 383ci roy383ci Engine 7 02-13-2005 06:14 AM
Windage Tray nomis30 Engine 1 03-15-2004 02:20 AM
windage tray woes black66 Engine 2 10-12-2003 05:21 AM
Small block Chevy maint studs and windage tray hahndo17 Engine 2 03-10-2003 08:39 AM
