mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2013, 10:21 PM
mounts
ibought a 65 mustang it had a 289 in it so just to say i had a big block 428 wanted in the car bad sunk al kinds o money in this project now im having troble finding the fram mounts iv tried three different kinds and nothing wants to line up to get bolted up any help please thinking going back to little low hp block dont want my heart broke thor i ned help please any one have this problem befor
Old 01-26-2013, 12:23 AM
mounts
Read some of the post on this forum. It looks like major modifications to get the 428 to fit. Will a 428 fit in a 1965-67 Mustang? - MustangForums.com
Old 01-26-2013, 07:45 AM
Wiki Edits: 27
Mustang II suspension.
There are kits to cut out the spring.shock tower, and replace with a flat stiffener plate,and install a Mustang II type design suspension with better geometry than the Falcoln based 65 design. that will give you enough room, and you will not have to look for the 67 FE Mustang. exhaust manifolds. When they installed The Fe engines in the 67's, usually the exhaust manifolds put a big gouge down the firewall. In the factory it was a 3 man job, one man on top each side and one guy in the pit under the assembly line guiding the tail shaft. I would Make a sub frame kit for the 65, similar to what you can buy for the 79 and later Mustangs, Go for the ladder type with a tube under the rockers as well ad the ones under the seats front to back. . I made mine. The 65-66 mustangs with the K high performance engines used thicker guage Convertible part number rocker panels. K engine cars also had more welds, A Fe is heavier and more horse power will put more stress on the body shell. Convertibles also have a curved inner rocker panel reinforcement with a flat plate between the inner and outer rockers. a box section reinforcement under the front seats and a bolt in 1/4 in thick tie plate to tie them together. You can use cross pieces in that area from your sub frame inner rails to tie it together, I would bird cage the front structure with tubing, tubing box at the radiator support, along the top of the inner fender panels then use the Mont carlo type bracing fire wall to mid point of the side walls close to where the shock towers were, then the side to side top brace. ( ps I was an engineer at Ford during those years ) and you will also want to change to a 9 in rear end.
help with motor mounts Pupsvette76 Hotrodding Basics 17 10-25-2011 06:37 PM
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 09:52 AM
Mounts Dave Korver Engine 2 02-18-2004 09:14 PM
Do I need new mounts? 60'Panel Transmission - Rearend 1 01-13-2003 05:55 PM
Where do the mounts go? duckhunter Engine 2 11-14-2002 05:46 AM
