Mouse Motor 305 differences - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2005, 01:25 AM
Hi,
Can you point out what the differences between carb and efi 305 sbc motors are? I found no site listing all changes in detail, but when shopping for rebuild kits for example you will typically find kits for engines up to 86 only, which means there must have been major changes.
Regards
Martin
Old 01-19-2005, 01:56 AM
Well for one thing the gasket kits are quite different. The pre 86 have a different rear end on the crank and have a two piece rear seal. 86 and newer have one piece. The 4 centre intake holes are also on a different angle. I believe the cam is slightly diff as well, less duration I believe. In the trucks it still is a flat tappet lifter, cars usually have a roller cam. Other than that the basics are the same.
