Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - move a 4.3 out of 1990 astrovan into 53 dodge B4B
Old 05-12-2012, 05:25 PM
LATECH's Avatar
LATECH LATECH is offline
X 2 with bob.
When you dissasemble take all the wiring dont cut any of it, unplug it. Study the wiring a little and you will see where it unplugs. Makes it easier when it comes time to reassemble as the plug ins will be a good hint. Also dont cut fuel lines. At the back of the motor there will be Flexible ones. You need to keep those intact. The need to be reused.
Take the gas tank out and keep the emmision evap canister and hoses all intact as well.Evap is nice as it keeps the fumes from stinking up the garage.
The exhaust is a no brainer, sawzall it whatever turns you on. Custom is in the mix there.
Fact is stranger than Fiction
