Move spring perches, or extend them - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2006, 11:29 PM
Ripped's Avatar
Last journal entry: First RoadCourse Video
I am considering moving the rear spring perches in 1/2" on my mustang. The traditional way would be to cut them off and weld new perches on.
I also thought of getting 2 new perches, cut off all but 1/2", weld these on to the inside of the existing perches, and then relocate the bolt hole inboard.
There are a couple of advantages I see. 1 it's easier to get the same pinion angle, 2 it's quicker, 3 it would be easy to restore the rear end to original, just by grinding off the additions to the inside of the perches.
I've never doen this, so what do you think , are there problems with doing it this way?
Old 12-08-2006, 02:16 AM
I moved my springs 3/4" inboard without altering the perches at all. I made some 1/2" spacers with the locating pin offset 3/4" from the locating hole under it and clamped them in. The shock plate is wide enough to accomodate the extra width.
Old 12-08-2006, 08:04 AM
Ripped's Avatar
That is an absolutely BRILLIANT IDEA!
Since I am already using a 1" (lowering) spacer, I can just modify the spacer.
Wow well, when I get this car on the road, if I'm ever in your area, or if your ever out here, I'll have to take you out for a brewski!
That'll save me a ton of work!
Did you notice any handling changes, when you moved the springs inboard?
Old 12-08-2006, 08:49 AM
The change involved more than moving the springs inboard. I went from old saggy monoleafs on an 8.2" Chevy rear to 3000# Mopar SS springs, new shocks and a Versailles rear. The change allowed me to run a wider tire, which allowed me to go faster at the strip. At the same time I was moving springs, I installed frame connectors, new front shocks, springs and a front sway bar, so the 'after' handling was quite improved from the 'before' handling.
1971 Nova spring perches? 1971 Nova Transmission - Rearend 3 12-04-2006 01:28 PM
700r4 TV plunger spring AngliaBob Transmission - Rearend 3 01-30-2005 08:17 AM
Who makes a 52" x 1.75" leaf spring? jpd37 Suspension - Brakes - Steering 5 10-14-2004 11:59 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
Proper throttle spring placement willys36@aol.com Engine 1 11-13-2002 07:19 PM
