Moving a 3 speed from column to floor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2006, 08:48 PM
Hello,
My ’46 Chevy has a 3 speed on the column, but I want to move it down to the floor. What is the best way to go about this? I was told of a “kit” out there that I could bolt on and be on my way, but never found it. Swapping out the transmission with one from a ’46 ˝ ton pick up is another option; do I have any other options…? If not, what should I expect in going with either of the two? Thanks!
Old 11-30-2006, 04:40 AM
This was a common thing in the 50's & 60's. Just get a floor shifter for your transmission/car and mount it according to instructions. It will require a hole to be cut in the floor.
Lately I've seen people putting previously converted floor shifts back to column shift more than the other way.
JA
Old 11-30-2006, 07:26 AM
dinger's Avatar
You will need the arms that fit on the trans, they will need to be flipped over so your shift pattern won't be backwards. Dan
Old 12-01-2006, 10:09 AM
Thanks for the guidance.
Old 12-01-2006, 10:12 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Go to Jegs or Summit....you can get a floorshifter from them....I think Speedway has them also. Its a kit..it comes with the shifter, shifter boot, shift lever and knob, shift arms and linkage.
Old 12-01-2006, 11:15 AM
Jegs has this item(Hurst Indy Qualifier 3-Speed Shifter) which i will be purchasing. Thanks again
Old 12-02-2006, 01:38 PM
is your car stock? if not why not install a t-5 and 55 and up open rear end. its darn near a bolt in job.
Old 12-04-2006, 09:30 PM
At this point the car is stock and as soon as i am able i will stuff a new drive-train...what? i am not sure but i will keep you guys posted. Thanks Henry for pointing me in the direction (Jegs has the parts i need) and to all for your suggestions.
« TH350 Leak | th 350 »
GM steering column tilt/wobble repair HELP (pics inside) camaroguy1969 Suspension - Brakes - Steering 18 03-05-2009 12:37 AM
floor fabrication johnnymopar Body - Exterior 2 03-13-2006 07:00 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 09:35 AM
console column to floor column questions LoudMalibu Interior 1 04-24-2003 06:56 PM
