?? moving a 4 post lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2007, 06:40 PM
I'm moving approximately 12 miles and I would like to move my Eagle 7000 4 post lift, without disassembling it. Any ideas would be appreciated.
Thanks.
Old 10-12-2007, 07:04 PM
Rollback or a open car trailer maybe
And I am moving this to the Garage and tools area ... where hopefully you will receive the answers you need ...
Old 10-12-2007, 07:31 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
I've done this with two lifts. They kind of are a pain to disassemble.
We put the lifts up on their casters, and lowered the ramps to their lowest point allowed with the casters on. Then we welded some 1 1/2" angle between the posts, kind of like making a temporary rectangular frame around the outside of the posts just above the ramps. Followed by welding cross pieces to the temporary frame for rigidity, and then pulling the whole thing up onto a flat bed car hauler. The frame and the cross braces kept the whole thing rigid (or rigid enough) while moving it. After relocating the lift, cut the welded pieces off. I suppose we could have drilled and bolted instead.
Old 10-12-2007, 11:00 PM
Just a couple of thoughts. With the ramps down low the lift should be pretty stable. What about using tie down straps or some come-alongs or chains and boomers around the top or diagonally to stiffen it up. Or just secure it down from the top of each post to the trailer. Something to think about.
Line-O-Tronics two post car hoist slarsen47 Garage - Tools 19 12-01-2009 02:28 PM
Warning fellow rodders of this 4 post lift truth be told 427 Garage - Tools 8 09-17-2007 10:48 PM
Hotrodders Bulletin Board Guidelines Jon Hotrodders' Lounge 0 10-09-2005 07:39 PM
4 post lifts Beenaway2long Garage - Tools 11 01-28-2004 07:38 AM
