moving 610lb compressor - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-22-2009, 06:29 PM
sqzbox's Avatar
My pipes are my music
Now that was a good driver!
  #17 (permalink)
Old 10-28-2009, 07:10 AM
aminga's Avatar
Last journal entry: Cleaning and Powder coat
Originally Posted by 302 Z28
If it's a vertical compressor be very careful, they tip over if you breath on them a little to heavy. I used my engine hoist to move my vertical compressor into place.
Vince
Same here.
We had to get mine off of the truck as well so my neighbor and I built "forklift" using some steel tubing I had and the bucket on his tractor. Set it on the driveway and then picked it up with the hoist.
  #18 (permalink)
Old 10-28-2009, 07:12 AM
aminga's Avatar
Originally Posted by metalmeltr
Don't take it off of the pallet. This way you have the wood for vibrayion dampening and your slab wont endure vibration though th whole thing because of the compressor being bolted to the floor. Also if you move it will be much easier to transport if it is on the pallet.
Some 1" thick rubber pads under the feet will work much better than the pallet. Some places sell them but if your near a grain elevator or something similar you can find old belt material to make your own.
  #19 (permalink)
Old 10-28-2009, 08:42 AM
sqzbox's Avatar
Improvise, adapt, and over come! It's all mind over matter! You might even come up with an idea for the home made garage tool's that work forum.
  #20 (permalink)
Old 10-28-2009, 11:33 AM
daoldbuick's Avatar
If you leave it on the pallet you could have water cleanup issues when you drain the condensation out of the bottom of the tank.
will this air compressor plan work? snorulz Garage - Tools 16 05-07-2012 10:34 AM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Moving my compressor (electrical) S10xGN Garage - Tools 5 03-07-2007 10:49 PM
moving a compressor, have a question pigjamelectric Garage - Tools 3 11-24-2006 09:37 PM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
