Moving the distributor 1 gear tooth - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2004, 09:04 AM
66Caprice's Avatar
Move It On Over!
I need to get a little bit more advance on my timing, but the vacuum advance housing hits the intake. So, the question is, which way to move the distributor?
When setting the timing, I rotate the distributor counter-clockwise to get more advance. I'm thinking I need to lift up the distributor and turn in clockwise one gear tooth and set it back down. Is that right?
Old 10-10-2004, 09:18 AM
Re: Moving the distributor 1 gear tooth
Yepp thats it,,..
Old 10-10-2004, 09:21 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Or you could just move the wires one notch.
TRoy
Old 10-10-2004, 09:29 AM
TRoy
I agree with Troy.. but you need to do your spark timing again,,..
Old 10-10-2004, 09:33 AM
66Caprice's Avatar
Move It On Over!
I like the idea of moving the wires better. The wires would be moved counter-clockwise?
Old 10-10-2004, 10:04 AM
Only takes a mark on dizzy rotor and housing , a spanner and remove and re,,slot the dizzy and your away ( without having to pull and replace spark leads ),,..
Old 10-10-2004, 11:22 AM
66Caprice's Avatar
Move It On Over!
I went with Troy's idea of moving the wires over.
Thanks!
