Moving ECM to Interior - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2010, 06:34 PM
sparkydog's Avatar
Spa Mercenary
Last journal entry: Updates July 2012
I am transplanting a late 60's truck body onto the running chassis of a 97 GMC truck. I'm expecting things to get a little crowded under the new/old hood. One of the things I could move out of the engine bay is the ECM unit.
Has anyone done something similar - moved their ECM into the interior of their car? Where did you mount it and were there any problems or downside?
Under the dash is obvious but I was thinking more like under the front seat.
Thanks
Old 03-10-2010, 09:58 PM
as long as you don't cut the wiring harness , but will it not go on fender well ?
what year, 60 what truck ?
Old 03-11-2010, 10:09 AM
sparkydog's Avatar
Spa Mercenary
Guess I didn't do a good job of explaining. When I take the body of a 67 IH pickup and put it on top of a 97 GMC truck chassis then all of the modern truck engine bay hardware will have to fit into a smaller space under the hood of a 67 IH.
I will do my best to keep everything inside the new space. But it will get crowded. Between the battery, the Vortec air intake and the ECM, I have some options. I thought that maybe it would be easy to relo the ECM into the interior of the cab. I was even hoping that there was an aftermarket harness adapter so I wouldn't have to splice the harness to extend the loom.
Old 03-11-2010, 11:48 AM
evolvo's Avatar
Heathen
sparkydog,
When I installed the '98 GM SFI V6 into my '67 Volvo wagon I moved the ECU and the coil pack to the top of the tranny tunnel inside the firewall. I did cut up and re-solder my harness, but it started the first time and runs great. I think there is a jpeg of this in my photo album.
Good luck
What paint colors will match this interior? tcruise Body - Exterior 9 10-24-2005 02:27 AM
Rust on Interior of Body joeford Body - Exterior 1 05-08-2005 04:33 PM
new interior coverings? Dragon J Interior 24 09-25-2003 11:50 AM
changing the color of my interior bigwildgrin Interior 16 07-07-2003 01:17 PM
Exterior vs. Interior mitmaks Body - Exterior 1 06-07-2003 08:45 PM
