moving a knock sensor. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2012, 09:00 PM
briansansone's Avatar
4 chevys and a ford
The new chevy block I have installed is set up for an older and larger knock sensor (This is a pre 2000 block in a 2001 van). The new block has a 1/2" hole, while the 2001 block uses a smaller bolt to attach the sensor (2000 and up).
How should I deal with this?
There was no heli coil configuration I could find to work, as the thread
count and size of the hole are different .
Could I move the sensor to the side of the head? Or will it not read correctly
from the head?
I also considered packing the hole with epoxy, then tapping for the correct
size bolt. But then I read the sensor requires a precise torque amount. I'm afraid I couldnt torque it correctly into an epoxy base.
Any Ideas?
Thanks
Old 06-07-2012, 01:14 AM
DoubleVision's Avatar
Chevy was placing knock sensors in the bell housing in the early 90's and I didn't see how it would work too good since it was a open area, but they worked and worked nicely so relocating it to almost anywhere else on the engine will work fine.
Old 06-07-2012, 03:58 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
How about a reducer?
Click
Old 06-07-2012, 10:58 AM
Sometimes the knock sensor relies on an electrical ground when screwed into the engine. Epoxy probably will not conduct electricity, so do not use it.
Knock Sensor tommy evans Engine 5 08-21-2010 07:02 PM
Knock sensor?? weirdbeard Engine 2 03-26-2006 08:08 AM
Moving an LT-1 Knock Sensor Alloways Speedstar Bumpstik General Rodding Tech 18 02-25-2003 10:53 AM
Moving an LT-1 Knock Sensor Bumpstik Engine 3 02-16-2003 07:48 AM
Moving an LT-1 Knock sensor Bumpstik Engine 0 02-15-2003 05:52 PM
