Moving trans shifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2009, 07:26 AM
I have a 29 5 window that I need some help making it fit my 6'4" body. 3 problems, shifter location, brake pedal locating, and steering. If there was some way to electrify the shifting, i.e. put it on the dash with buttons, that would solve 2 problems. Anybody every done something like that. The steering is a Mustang II. I need power steering. What are my options? And the brake petal is through the floor, which I guess is pretty common in these cars. Can it be made to swing from the dash? THanks.
Old 11-08-2009, 12:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are power racks for the MII front ends. And WILWOOD and others have dozens of swinging brake pedal/master cylinder units to choose from.
THESE folks offer a paddle shifter that mounts to the steering wheel- nothing on the trans tunnel. TCI also makes a version of a paddle shifter.
Old 11-08-2009, 01:23 PM
Irelands child's Avatar
Not only are there paddle shifters($$$$) - there are cable shifters which allow you to put it almost anywhere - B&M have several that work nicely. As far as 6'4", so am I - and my car is a '31 roadster(see the AVATAR for how it was 3 years ago) with a Lokar 16" shift handle, a 6" recessed (yep, it sure is) firewall with BMW Recaro seating with OEM slides and fabricated adapters bolted to the floor. It's tight!! I have TCI IFS and Dodge Omni R&P steering but don't need power assist.
Dave W
Irelands child
4x4 1994 Trans problems ???? sinlow1980 Transmission - Rearend 2 07-16-2007 07:37 PM
Will a Z gate shifter work with manual vlv body? lumberjacknooj Transmission - Rearend 1 06-01-2007 09:43 PM
Galaxie automatic to manual trans conversion galaxieguy3 Transmission - Rearend 0 04-25-2007 08:45 PM
4t60 Trans Question david hill Transmission - Rearend 1 04-10-2007 09:58 PM
What automatic shifter is good novadan Transmission - Rearend 3 02-23-2006 11:45 PM
